Sponsored by: CARiD
Bilstein Write Up Anywhere???
Old Dec 2, 2009 | 03:46 PM
mhockey9090's Avatar
welll title says it all. Bc its came with like a nut for the shock the thing that sets it in place and some other circle thing i think goes on top
Old Dec 3, 2009 | 09:11 PM
did they not come with instructions?
IIRC the rubber sleeve gets pushed down and stretched over the shock shaft, then the metal spacer goes on, then installed into the strut assembly, then the nut goes on top
Old Dec 3, 2009 | 11:31 PM
HERES WHAT IT CAME WITH. I BOUGHT THEM FROM ANOTHER MEMBER ON HERE BC HE WAS SELLING HIS TRUCK AND HAD THEM LAYING AROUND.
HERES HOW MY CURRENT COILOVER SHOCK SETUP LOOKS LIKE. WILL I RUN INTO ANY PROBLEMS?
Old Dec 4, 2009 | 12:14 AM
greencrew's Avatar
I wonder if you can find them online? This is all I found.
Front Height Adjustable Leveling shocks
Circlip
Old Dec 7, 2009 | 12:25 AM
Rubber sleeve goes down first, and gets stretched out, then the metal spacer (top left) then the ring gets locked on the shock shaft to mount the coil perch on the shock, and i dont remember what the metal + thing goes on, maybe part of the bumpstop, but i dont remember for sure
and nut on the top
Old Dec 8, 2009 | 02:22 PM
ok thanks alot man i dont know either but anyone know of a good coil spring compresser and how long should it take to get done?? couple hrs or so?
Old Dec 8, 2009 | 08:27 PM
autozone rents one, just make sure its strut style (outside coil) spring compressor
If you are doing it by hand without air tools, i'd allow for 4-5 hours, since the spring compressor will wear you out
Old Dec 8, 2009 | 09:12 PM
ill have access to air tools in a garage bay
Old Dec 8, 2009 | 10:41 PM
blackedoutV6's Avatar
hm, im sure once you get the your old set up out youll be able to tell what that + looking thing is for, im pretty sure it goes on top of the shock?
idk
it took me about 1 1/2 per side to do drop struts on a NNBS silverado. not all that hard to do once you figure out how everything comes apart
Old Dec 10, 2009 | 11:20 PM
greencrew's Avatar
and nut on the top
I still have the instructions:
From the top
1. M10 lock nut -
2. Steel spacer - (metal spacer)
3. Rubber sleeve -
4. Cap - (metal + thing)
5. Spring seat holder
Then the circlip gets mounted in one of the grooves and determines your ride height.
