Sponsored by: CARiD
Steering play after lift
Old Nov 9, 2009 | 02:31 PM
johnbaughman85's Avatar
04 4x4 lariat. i put a 6in procomp stage 2 lift on with with 35s and now i have play in the steering. also when i hit bumps and things in the road the steering wheel kind of jumps. is there anyway to help with this. also i have an aal. when i hit a bump the back of my truck jumps pretty bad its just not that great of a ride. any advice or comments would be helpful
Old Nov 9, 2009 | 02:41 PM
dilloncawthon's Avatar
idk about the play in the steering, mine is pretty tight even with 38's. you seem to have bump steer, you can get some steering stablizers to help with that.
Old Nov 9, 2009 | 02:46 PM
i know that fabtech makes some steering stabilizers for their lift. does procomp or anybody else make some for the lift i have
Old Nov 9, 2009 | 04:51 PM
lost cause's Avatar
i would check your steering stabilizers and also your idler arm and pitman arm. other than that im not too sure.
Old Nov 9, 2009 | 08:15 PM
b2therad's Avatar
Your tie rod ends may be going out too. That could cause your steering wheel to be a bit jumpy or even seem like you have to hold your steering wheel at a odd angle to go straight.
The only thing you can do about the rear is get a leaf pack made with the same amount of lift. Deaver and Skyjacker both make them, and Skyjacker is the cheaper of the two.. you get what you pay for though. (not knocking Skyjacker quality)
Old Nov 9, 2009 | 09:41 PM
im thinking i might try the steering stabilizer, but i will check the tie rod ends. what if i took the aal out and just put in a bigger block. would that ride better
Old Nov 9, 2009 | 09:48 PM
ridin35s's Avatar
Get fabtech steering stabilizers. Thay are the only ones made for your truck I have them on my truck
Old Nov 9, 2009 | 09:50 PM
so the fabtech will work even if i have a different lift. and where is the best place to get the stabilizers
Old Nov 9, 2009 | 10:11 PM
b2therad's Avatar
Yes it would ride a lil bit rougher than stock in the rear if you took out the AAL and put bigger blocks.
Old Nov 9, 2009 | 10:37 PM
so are you saying that putting in the bigger block would be better than having the AAL
Old Nov 9, 2009 | 11:58 PM
b2therad's Avatar
If a better ride is what you are looking for.. yes.
Old Nov 10, 2009 | 02:44 AM
ponbrispla's Avatar
Great info! Really informative. It is helpful for me.
Yaaa... I am here to share with you. Great info!!!
Old Nov 10, 2009 | 11:32 AM
yeah i dont really care to much about hauling stuff in my bed. i hardlly ever do so if the block will give me a better ride then thats what im going to do.
