Sponsored by: CARiD
squeak in the front
Old Oct 6, 2009 | 12:09 AM
hoss66's Avatar
Arrow squeak in the front
so my truck has got a squeak in the front end and i cant figure what it is. it only does it when turning to the right. If it was the ball joints i would get a noise when i was going over bumps also correct? The truck only has 36k miles.
Old Oct 6, 2009 | 05:11 PM
hoss66's Avatar
somebody has to have an idea.
Old Oct 7, 2009 | 05:13 PM
hoss66's Avatar
come on guys i need some help.
Old Oct 7, 2009 | 06:32 PM
bor543v's Avatar
you got a lift of any kind?
Old Oct 7, 2009 | 06:52 PM
krash kendall's Avatar
Pitman arm.
Old Oct 7, 2009 | 10:42 PM
1bad86vmax's Avatar
It's a Ball Joint . Mine started out only squeaking while turning ,then started squeaking over bumps as well .
Old Oct 7, 2009 | 10:59 PM
hoss66's Avatar
yeah i have a leveling kit. so the ball joints may make noise only when turning? How do you check pitman arm? Also could the outer tie rod be making the noise?
Old Oct 7, 2009 | 11:31 PM
bor543v's Avatar
Is your leveling kit urethane?
Old Oct 8, 2009 | 12:42 AM
hoss66's Avatar
no its steel.
Old Oct 8, 2009 | 02:42 PM
rpxr400's Avatar
Mine has a squeak when the suspension moves - only the driver side. Same mileage - 36.9k. 2" AS leveling kit. I haven't looked - are the ball joints serviceable/greaseable?
Old Oct 8, 2009 | 04:33 PM
hoss66's Avatar
not really. you can take a needle on a grease gun and stab the boot to fill it with grease but no grease zerks.
Old Oct 9, 2009 | 10:44 PM
hoss66's Avatar
How do you check pitman arm? Also could the outer tie rod be making the noise? Well i just went out and jacked up the passenger side and it doesn't make the noise when it is jacked up.
Old Oct 11, 2009 | 01:56 PM
hoss66's Avatar
does anybody know why it wouldn't make the noise when i jacked it up.
Old Oct 11, 2009 | 06:37 PM
pappastangle06's Avatar
when adjusted my torsion bars i had a squeak in the front end on the passanger side when i hit a bump and took off and stoped fast. it was comming from the torsion bar in the front where it ties into the susp. also the upper ball joint was spitting out rust when i greased it.
Old Oct 11, 2009 | 07:05 PM
hoss66's Avatar
i dont have any torsion bars.
