adjustment needed with Pro comp lift
Can i raise my front end up a little bit with my Pro Comp lift installed. I am having slight tire rub when wheels cranked all the way. If i can, how do i do it??
It is 6" lift (no coil overs only spacers) in an 06 Screw. Also, i did already do a little trimming where I can.
Sounds like it must be an 04-08 F-150. Your best expensive option is to install a set of OEM replacement Bilstiens or a set of Pro COmp's MX6 coilovers. Both feature adjustable preload so you could add 1 or 2 inches of lift.
