Sponsored by: CARiD
Squeek and Clunk From Front End, Help!!
Old Aug 22, 2009 | 06:33 PM
JTDEERE's Avatar
I've been having this problem for awhile now, there's this squeek coming from the front end everytime I hit a bump, even small bumps. There's also a clunk coming from the same place when I make a sharp turn, sharp turn over a curb going in/out of a driveway, or make a sharp turn over a bump. It's especially noticable if I drive in our back yard over a bunch of short hills at 5mph +. I've been lubing everything up underneath, even tried Deep Creep. I just installed new Rancho shocks a few minutes ago. I went for a test drive and everything is still there. Any suggestions on what could be causing this would be greatly appreciated!! Thank you!!
Old Aug 22, 2009 | 06:43 PM
rhdf150's Avatar
Check your sway bar links & bushings. I had a clunking noise for a while and finally tracked it down to a loose sway bar bushing bracket. Good luck!
Old Aug 22, 2009 | 07:08 PM
tbraquet's Avatar
I've been having a clunking noise and just found out it is my lower ball joints.
