Front end leveling not so sure
After reading this it sounds like a PITA !!!!! And is also says it will ride a little rough.. Then a front end alignment .. So I am looking at like 107.00+++ about 100.00 for an alignment and then of course I still need new shocks .. And then I have to go and find a torsion bar unloader tool.. and probably a better torque wrench than I have ... Other than looking better is there any reward to leveling the truck ???
I read this
http://www.tuffcountry.com/NewFiles/22906.pdf
I read this
im guess you have an 03- earlier since your asking about torsion keys and stuff like that but just crank them to get the 2" instead of all the confusion. may ride a little stiffer and if you need to get new shocks replace them at the same time as cranking the torsion bars so you can get your alignment once after you get it all done
