Sponsored by: CARiD
2.5in or 3in Leveling Kit
Old Jul 31, 2009 | 12:46 AM
militia310's Avatar
Hey whats up everyone, new to this fourm and new to ford trucks in general, Ive owned alot of trucks but love my Ford, Ive got an 05 F150.
Anyways, I know I shold search this, but im wanting to get the leveling kit (just like everyone else), and I see that some perfer 2.5, and some perfer 3, whats the difference? And which will give me less problems. I plan on running 35's with either 17's or 18's. And will the 3 make the front end stick up??
Thanks guys!
Tsala.
Old Jul 31, 2009 | 09:50 AM
wandell's Avatar
Very few people will recommend a 3 inch leveling kit. Most everyone agrees that 2.5 inches is the limit. The 3 inch kits leave the ball joints at too severe of an angle to last. To fit a 35x12.50 tire with a leveling kit (on a 4x4) you will need to use the OEM wheels or an aftermarket wheel that is 8 inches wide with 5.5 inches of backspacing.
Old Jul 31, 2009 | 07:06 PM
aPINCHbetter90's Avatar
yea go with the 2.5" at most thats what Im running and then also an addleaf in the back or airbags. Then find a wheel with the right backspacing and offset to run 35's you have to find something close to factory specs I run 17x8's with +18 offset and dont rub at all after only minor trimming.
Old Jul 31, 2009 | 09:35 PM
jdruzik's Avatar
3" leveling kits will really alter the CV angle causing severe wear... I have a 2" kit and am running 34/11.50 R17s without rubbing or trimming...
Old Aug 1, 2009 | 02:52 PM
militia310's Avatar
Ok so it sounds like i should go with the 2.5 and it just sucks because i have a free set of toyo 35 m/t's sitting in my garage. What brands would you guys go with as far as the leveling kit??
Old Aug 2, 2009 | 05:15 PM
wandell's Avatar
Most kits are almost identical but some are priced 3 or 4 times the cost of others. Most people here have found the Autospring kits to be high quality kits at a low price.
Old Aug 3, 2009 | 12:31 PM
militia310's Avatar
So is this a good call for the 2.5?
http://cgi.ebay.com/ebaymotors/04-08...=p4506.c0.m245
and for the 3in?
Old Aug 3, 2009 | 12:51 PM
ksandefer's Avatar
Thumbs up
my friend put this one on his truck a few months ago with no problems (2008 f150)
I just ordered mine last week and will be installing it when it comes in. They are inexpensive but made very well.
http://www.hellbentsteel.com/catalog...it/category/5/
I will post a pic of his truck in my gallery.
Old Aug 3, 2009 | 12:56 PM
militia310's Avatar
Wow thats a steal for that price...if i do that kit and keep the stock wheels, could i run 35's?
Old Aug 3, 2009 | 05:13 PM
Im not sure if can run the m/t's because of them being real side biters, they may rub. If you choose from certain aftermarket wheels you would be able to get them to work without rubbing.
Old Aug 4, 2009 | 12:42 AM
militia310's Avatar
I am on a budget so as of now im doing only tires and the leveling kit wheels will come probably around xmas time, so as for now if you guys were in my shoes what would you do as far as tires go with keeping stock rims?
Old Aug 4, 2009 | 02:23 AM
UofKboy's Avatar
Depending on your budget, get you a set of Bilsteins adjustable shocks. If your in the need of new shocks too, this will kill 2 birds with one stone. The shocks have a 1in setting and a 2 in..... I would highly recommend them!!
Old Aug 5, 2009 | 02:23 AM
militia310's Avatar
Ok ill look in to that too, I plan on doing it this weekend still a little more research to do, as of now im doing the 2.5 leveling kit along with 33in nitto terra grappler tires,
and has anyone ever painted there stock chrome rims? Are those even real chrome, and could i paint them myself since i want them black and am on a budget....thanks guys.
Old Aug 5, 2009 | 11:59 AM
F_ast's Avatar
If i had to do it again I would go with the 2" kit. Both my 09 and my dads 05 sit nose high with the 2.5". His sits about 1" high, mine just under 2" high.
Old Aug 5, 2009 | 12:05 PM
militia310's Avatar
Yeah im going to go with the 2.5in kit, but keep in mind my truck is 2wd? Im sure that makes a difference right?
