Sponsored by: CARiD
Leveling "08 F150 Help
Old Jul 28, 2009 | 09:29 PM
HOYT04's Avatar
Question Leveling "08 F150 Help
Hey Guys...I'm new to the forum and have a question. I would like to get a 2" leveling kit, and run 18" rims. What is the biggest tire size I can run??? I can't stand any rubbing at all. Thanks for the advise and Pics would be great.
Old Jul 28, 2009 | 10:27 PM
wandell's Avatar
4x4 or 4x2? With a 4x4 you can fit a 35x12.50 using the OEM wheels but there will be minor rubbing on the control arms ast full steering lock. If you want zero rubbing, go with a slightly small size.
Old Jul 28, 2009 | 10:41 PM
HOYT04's Avatar
4X4.. It currently has 20" rims...I thought the 18" may look a little better..Do you have any advice (tire size) for the 20's if I keep them? Thanks
Old Jul 28, 2009 | 11:20 PM
1445f150's Avatar
A 33 inch tire would be a safe bet for 100% clearance. being a stock wheel you may find that standard sizes might be harder to find so look for a 285 or 305 in metric sizes and you should have no problems for both wheel sizes. Are u goin with a mud tire? if so i would recommend cooper discoverer stt. I have had really good luck out of them and they wear great
Old Jul 28, 2009 | 11:36 PM
HOYT04's Avatar
Thanks for the info...I probably will go with A/T tire...
Old Jul 29, 2009 | 01:13 AM
devs_05scab's Avatar
well a buddy of mine has an 04 xlt 4x4 and has a 2" leveler on it... he runs the 305/65/18 on there, it looks really aggressive but it does rub at full crank.. its not a bad rub but does rub.
Old Jul 29, 2009 | 12:07 PM
wandell's Avatar
If you keep the OEM 20's, I'd go with a 285/55-20 (33x11.50), 305/55-20 (33x12.50) or a 285/65-20 (35x11.50).
Old Jul 29, 2009 | 01:52 PM
HOYT04's Avatar
Thanks again guys..Looks like I will be going with 305/55/20. With 2.5 AS leveling kit. If I do choose to change to aftermarket wheels what type of offset do I need to look for? Pics always welcome.
Old Jul 29, 2009 | 05:00 PM
aPINCHbetter90's Avatar
I have a 17x8 wheel with 5.5" of backspacing and +18 offset with 35's and a 2.5" level. You just need to find a wheel with the right backspacing and offset a bunch of guys here have 35's on aftermarket wheels just gotta look around.
Old Jul 29, 2009 | 10:24 PM
wandell's Avatar
If you go with an aftermarket wheel, I'd suggest a 9 inch wide wheel with 5 to 6 inches of backspacing (and stick with 33's).
