RIZE 6" Block For Rear Lift
Rize is not tapered. If you want a tapered block buy a one-up-offroad block with a taper and be done with it. You'll need to buy some u-bolts also. They are not cheap and you'll most likely have to wait for it to be fabricated. Pretty trick block non the less.
So basically no-one makes it with there lift except Rough Country which isn't actually a block. I'll use the 5" Tough Country blocks I purchased and but some shims.
I'm taking it that no one has had any issues with there pinion angle since no one makes a tapered block? I guess my seal was just a bad seal that it started leaking and wasn't due to the angle.
As ya'll can see my rear sits lower than the front. It was level for about 2 weeks until the AAL's settled. If I'm going to change blocks and shim my rear end I want to try and get it up a lil more. I'm not sure exactly how much I need, but will take measurments this weekend.
What did you put on your rear to lift it?
The only blocks that are tapered in that size are one-up-offroad. They have them in dual pin.
http://www.trucktoyzstore.com/realm/...idcategory=125
You have to configure the block on truck toyz page.
polyperformance sells the dual pin shim kit. I bought mine from them and I have zero complaints with a rize block.
