Sponsored by: CARiD
Coil Spring swap
Old Jun 5, 2009 | 02:56 AM
TS2.5's Avatar
Smile Coil Spring swap
Can i put 2wd F250 coil springs on my 4wd 1994 F150 XL? i know it dosen't increase load capasity, just want stiffer ride.
Old Jun 5, 2009 | 06:05 AM
Veteran: Army
what year F-250?? what's the height difference between your truck and the F-250 you are considering??
Old Jun 5, 2009 | 03:07 PM
TS2.5's Avatar
All i want to know is will the 1995 2wd F250 coil springs fit my 1994 F150 4wd? There maybe an inch height difference.
Old Jun 6, 2009 | 10:22 AM
Veteran: Army
they should but nee to check and make sure that the spring rate is different before you take the time to change 'em
I'm sure they will considering the trucks are the same body and basic frame but I'd double check the allignment after the swap
have you considered that maybe a firmer shock is what you want
Old Jun 7, 2009 | 02:26 AM
TS2.5's Avatar
Yeah i'm putting monroe gas magnum shocks on it this week, i'll decide about he springs after i change the shock but i just wanted to know if the coil springs would work. My dad has a 1995 E-250 with a blown E4OD Tranny, it suspention is identical to the 2wd F250, do you think the coils from it would fit? like i swaid i'm not going to change the spring until the shock are done, but just really like to know.
