Sponsored by: CARiD
4" Rancho level
Old Jun 4, 2009 | 02:34 AM
mSaLL150's Avatar
Originally Posted by gatorbait10
did he have to add an AAL to the back or anything?
Nope, just the Rancho blocks in the rear and a 1.5" spacer on top of the rancho shocks up front.
I would measure your front and rear arches, see how much the difference really is. Daystar makes a 1" spacer, and autospring makes a 1.5" and 2" so you've got lots of options.
Old Jun 4, 2009 | 01:39 PM
fx4 for life 79's Avatar
measure and make sure cause the rancho should put you level
Old Jun 4, 2009 | 07:05 PM
Galaxy's Avatar
You guys are asking for trouble placing a levelin kit on top of a lift using a spacer to achieve the lift in the first place. The proper way to fix your situation would be a smaller block in the back...or the appropriate lift in the front, which ever your finances allow.
Old Jun 4, 2009 | 07:13 PM
IDNC76's Avatar
you need to buy new shocks with the rancho lift , i believe they do not use spacers to achieve lift
Old Jun 4, 2009 | 07:28 PM
gatorbait10's Avatar
there is an inch difference, 9.25" in the front well and 10.25" in the back.
Old Jun 4, 2009 | 07:38 PM
mSaLL150's Avatar
Rancho uses longer shocks, not a spacer. Placing a 1" Daystar spacer ontop of the Rancho shocks will be perfectly fine.
Old Jun 4, 2009 | 07:41 PM
with a 1.5" spacer would the front look a lot higher than the back?
Old Jun 4, 2009 | 07:49 PM
mSaLL150's Avatar
Nope. I posted a pic for you of that exact setup...
Old Jun 4, 2009 | 07:51 PM
Ohhh yes yes sorry about that, what about the 2" AS would that look fine?
