lifting my 2wd 7700 series
Hey everyone.... I am new to the board, and am already in need of some help. First off, I have about 2k to spend including new tires, wheels, and the lift itself. I have no idea which way to go. I know there are coil spacers for the front to level it out, and then I could put some 33 inch Mud Dawgs under it.... Or I could do that, plus add a 3 inch body lift and maybe fit some 35's under there. I'd probably stay with 33's tho unless I went up to a 6 inch lift. Just because I HAVE 2 grand to spend on it, doesnt mean I WANT to.... I would LOVE to get up to 6 inches of lift on it, but have no idea what to get. Any help would be appreciated!
Just about anyone that sells truck accessories (4Wheel Parts, Desert Rat, etc.) should have them. While you are installing them, I'd go ahead and install a set of adjustable camber bolts (they are about $40 at most parts stores). Some trucks need them to get the alignment within specs, some don't. Since they are pretty chead, I'd go ahead and install them. Personally, I'd add a 3 inch body lift and go with 33's. This will put you at about the same height as a stock 4x4 with the torsion bars cranked up.
