Sponsored by: CARiD
need some help?!?!?!?!
Old May 11, 2009 | 09:34 AM
jarred82's Avatar
i was thinking about getting a leveling kit for my 2004 f150. i guess my question is what should i do? you see i pull a trailer with a little weight behind me. should i go with 2" or 2.5" level kit? i already ordered bilsteins 5100 for the truck, would this help? i dont really want the truck to squat when pulling a load, and i dont want it to look werid when i'm driving around while not working
Old May 11, 2009 | 12:17 PM
wandell's Avatar
If you ordered the Bilsteins you don't need a leveling kit because they feature adjustable spring preload allowing you to lift the front 2 inches. If you want the best setup out back, a set of airbags would be best. You can just inflate them when you tow and then deflate them when you are not.
Old May 11, 2009 | 02:45 PM
jarred82's Avatar
what if i didnt want air bags? would it still squat alot? i pull a 16' enclosed trailer with the trailer it is like 6000lbs
Old May 11, 2009 | 07:01 PM
aPINCHbetter90's Avatar
Go with an add a leaf, I have read from a few guys that there very happy with it in regards that it maintains factory ride pretty well and installation in a very easy with them.
http://cgi.ebay.com/ebaymotors/1-1-2...Q5fAccessories
Old May 11, 2009 | 10:56 PM
wandell's Avatar
Yep, that's another option.
Old May 12, 2009 | 09:08 AM
jarred82's Avatar
i have thought about adding a leaf, sounds like thats the way to go for me. also should i still use a spacer in the front if so, which brands and why, poly or steel?
Old May 12, 2009 | 11:19 AM
wandell's Avatar
I'd go with the AutoSpring kit because it's a good kit at a good price. Honestly, a leveling kit is a pretty simple product and they are all about the same. There is no reason to pay $200 for one when an identical kit is $80.
Old May 12, 2009 | 11:32 AM
jarred82's Avatar
are they metal or poly
Old May 12, 2009 | 02:16 PM
mdhawkin's Avatar
They are metal, you can get them powder coated vs painted for only $10 more.
Old May 12, 2009 | 02:36 PM
jarred82's Avatar
ok thanks, is that a 2inch or 2 1/2 ???
Old May 12, 2009 | 10:48 PM
wandell's Avatar
Autospring offers several sizes. 2.5 is the largest you should go.
Old May 13, 2009 | 09:27 AM
jarred82's Avatar
thanks wandell
Old May 13, 2009 | 08:06 PM
sharpshooter109's Avatar
but you dont need a leveling kit because you have the blistens, right?
Old May 13, 2009 | 10:59 PM
fx4d's Avatar
I was also thinking if you go the route by adding a leaf wouldnt it give you a stiff ride in the back when your not hauling your trailer.
Old May 14, 2009 | 03:14 PM
jarred82's Avatar
not sure would it?
