Sponsored by: CARiD
Lifting...
Old Apr 14, 2009 | 11:06 PM
CHUCKO1404's Avatar
Go with Fabtech and will not have to do anything! Don't go 37" unless you will be regearing. No need for anything but Fabtech 6"
Old Apr 14, 2009 | 11:26 PM
grantoser's Avatar
yeah i would like to go with fabtech... its just the money i could save just using a pro comp.. :S
does anyone know what size rear block the pro comp comes with? dont they stack them or something? would a 5.5 inch block solve the sagging problem?
Old Apr 14, 2009 | 11:33 PM
grantoser's Avatar
this is the exact look id want... its from the pro comp catalog. Id get those 6001 Pro comp wheels as well, pictured on this truck...
Old Apr 14, 2009 | 11:45 PM
CHUCKO1404's Avatar
How about these?
Old Apr 14, 2009 | 11:47 PM
grantoser's Avatar
yours are sweet too man. I just like the beefy look of the 6001's rapped in toyo's :P
Old Apr 15, 2009 | 12:05 AM
grantoser's Avatar
anyone know what the procomp rear blocks are? would switching for a 5.5inch block fix the sagging problem?
Old Apr 15, 2009 | 08:20 AM
fx4 for life 79's Avatar
yes a 5.5" block should level it, i did a 4" block and 1.5" aal and mine sat level
great choice on wheels
Old Apr 15, 2009 | 10:36 AM
rojoscrewkab05's Avatar
whats wrong with a truck that has what u guys call "sag" in rear
Old Apr 15, 2009 | 11:09 AM
SportTractoF150's Avatar
because it looks bad. a lot of us here don't care for the bulldog stance that seems to be fairly popular in socal
Old Apr 15, 2009 | 11:45 AM
tnsilverfx4's Avatar
You can use shims on top of the blocks or spring for the aal. I had the pro comp with coilovers and needed both.
Old Apr 15, 2009 | 12:32 PM
must be a socal thing..thats called a prerunner stance.lol
never heard of a bulldog stance.
Old Apr 15, 2009 | 11:52 PM
grantoser's Avatar
well thanks guys i think ill just buy a 5.5inch block when i get the pro comp lift and hope its tall enough to make it at least even in the back. Ill let you know if i need anymore help. I appreciate it!
-g
Old Apr 19, 2009 | 10:26 PM
wingman4's Avatar
Grantoser I think you and i are doing the exact setup... I am just debating on wheels... between the 6001s, 1079s, 7005s, and the 8069s... too many choices... choices, choices... :P
Old Apr 20, 2009 | 03:52 PM
BlkButy's Avatar
I went with the Procomp 6" on my 04 SCrew and it did have the SAG in the rear. Had to drive it a week like that until the AAL came in. If you go with Procomp order the AAl at the same time. Here is a PIC of my old 04. It had the 6" procomp and a 3" Body lift with 37" tires.
Pic #1
Pic #2
Pic #3
