Sponsored by: CARiD
Going Under the Knife!
Old Jan 28, 2010 | 09:56 AM
  #331
car_lost's Avatar
so you can get some ideas:
http://www.suicidedoors.com/catalog/.../bridge-plates
you should also check out the member projects section at www.s10-forum.com for more ideas.
Old Jan 28, 2010 | 10:05 PM
  #332
1fast4.6's Avatar
Old Feb 1, 2010 | 07:08 PM
  #333
1fast4.6's Avatar
Well it looks like those two air tanks i made up are about 1/2 inch too big. cant get them to fit under the body. Sooooooo im going to downgrade to some 6" pipe to make some more airtanks.
Back to the drawing board!!!
Old Feb 3, 2010 | 09:16 PM
  #334
freekyFX4's Avatar
Wow, awesome build! This thing is going to be badass!
Old Feb 4, 2010 | 12:06 AM
  #335
blackedoutV6's Avatar
dang i bet those air tanks weigh a ton
Old Feb 4, 2010 | 01:35 PM
  #336
1fast4.6's Avatar
And you are correct. I started lastnight on some new airtanks but havent gotten them completed.
Old Feb 4, 2010 | 01:51 PM
  #337
if you think about it, could you snap a couple pics of your crossmember notch?
for some reason i thought you'd have to notch it more than that for the DS to clear, but im probably wrong.
i need to notch mine soon and might as well notch it big enough to lay out...
Old Feb 4, 2010 | 08:14 PM
  #338
1fast4.6's Avatar
just a 4 inch piece of pipe cut in half. if I was to do it again id go with a 5 inch pipe. and I had to notch mt cab out aswell
Old Feb 4, 2010 | 09:20 PM
  #339
cool, thanks for the tip.
Old Feb 18, 2010 | 06:54 PM
  #340
bagtodrag's Avatar
Originally Posted by 1fast4.6
More pics
With that front upper plate and those small "gussets" your going to run into the risk of that upper plate bending upward. Since its just welded to the top of the frame and those "gussets" are just too small. If you wanted to go with that look you should used some small quarter inch tubing to use on both sides for strength. Or something like how I did on my F150....
Old Feb 21, 2010 | 04:27 PM
  #341
1fast4.6's Avatar
Well ive been pretty busy. Getting powdercoating quotes.. Cleaning everything. And I think ive determined what colors i am going to go with. Silver and Black. They have what they call a chrome color... but its basically a silver. So i had to choose a color that went well with silver. They didnt have any orange color that could come close to matching my "Molten Orange." The black i picked out looks dripping wet. Put a little chrome next to and it will pop.
Also i found out in order to powdercoat you have to remove everything rubber or plastic. That includes all your seals in your rear end, front hubs, driveshaft, Brake calipers, 4 link bars, Everything.
Reason for removing all of this is because after they apply the powder they bake it at 400 degrees.
Ive got everything apart and im gonna sandblast it lightly again. between parts ive orderd with powdercoating on them already... and the wd-40 i sprayed on everything i blasted to keep it from rusting, its gotta be good and clean.
Parts are piling up!
Old Feb 21, 2010 | 04:51 PM
  #342
Veteran: Army
make sure you paint / POR-15 the under side of the bed and cab while you're at it
Old Feb 21, 2010 | 05:02 PM
  #343
1fast4.6's Avatar
yup when the frame is gone that's when im attacking the cab/bed
Old Feb 21, 2010 | 09:04 PM
  #344
CedartownDawg's Avatar
I just read this from the beginning and wow.
Amazing stuff, fast.
I'm jealous of your skills.
Old Feb 21, 2010 | 09:15 PM
  #345
Looking good so far man. I want my truck torn apart and painted some day. That's a ton of work
