Sponsored by: CARiD
Adjusting headlights
Old Mar 19, 2009 | 03:49 PM
BASSGODD's Avatar
How do you adjust the headlights on a 2008 FX4? I got a leveling kit installed and now my headlights are blinding everyone. Plus my line of sight would be better if I could see the road closer to my truck!
Is it hard? If you got pics, hook it up please.
Thanks.
Old Mar 19, 2009 | 04:02 PM
Hespen537's Avatar
Its not hard. When you open the hood, behind the headlight fixture, theres a single bolt sticking out. It adjusts it up and down. There isint a second one for left and right, 04-08 models didnt need that.
Old Mar 20, 2009 | 12:33 PM
BASSGODD's Avatar
Thumbs up
Thank you, I will check that out this evening!
Old Mar 21, 2009 | 10:56 AM
Maniac01's Avatar
Is it really that easy?
Old Mar 21, 2009 | 11:20 AM
minimonster17's Avatar
yeah, its not that hard, aiming them just right takes a little bit of patience, though. the easiest way to do this is too pull up to a brick wall to see exactly where the lights are pointing, then reaim as necessary.
Old Mar 21, 2009 | 11:25 AM
brianjwilson's Avatar
Yes it is easy. But I have re-aimed mine a few times trying to get them right.
Find a wall where you can pull back 25 feet from it on level ground. Measure how high the center of the headlights are (there is a small clear dot on the headlight face), and measure that high on the wall, put a mark there. With the low beams, the majority of the light should all be below the line, so that you light beam goes down as it travels further away.
I did the same with the fogs, then made small adjustments to make sure I wasn't blinding anyone.
Old Mar 21, 2009 | 11:46 AM
cheesepuff1's Avatar
i've been getting flashed to,will try to adjust mine to..thanx hespen537
