Sponsored by: CARiD
whats it mean
Old Feb 27, 2009 | 06:21 PM
Darkyst's Avatar
whats it mean
i did a search and too many post with the words popped up but none with an explaination of what it means.
What does everyone mean when they say backspacing?
i hear these terms when people talk about lifted trucks
Backspacing / offset / application
i know 35 is tire size 12.5 is width i think but what is the 3rd number?
35x12.5x9 for example
whats it all mean?
Old Feb 27, 2009 | 06:24 PM
fx4 for life 79's Avatar
a 35x12.5x9 will not fit, 9 is the wheel size
Old Feb 27, 2009 | 06:27 PM
Darkyst's Avatar
do u mean that 35x12.5x9 wont fit a 6"lift?
and what about the rest of the Q's? anyone know?
Old Feb 27, 2009 | 06:33 PM
Eff One Fifty's Avatar
okay the last number on the tire markings is the wheel size, my tires are 37X13.50XR20 i have 20" wheels so hence the R20.
backspacing.
okay backspacing. it is the distance from the inner lip of the wheel to where your mounting surface is.
hers an example.
your wheel is say 10" wide. take your wheel and look at it so the outside ( the part that people will see) is facing away from you, from that inside lip all the way to the mounting sureface ( where it will push up against the hub) is your backspacing.
and easy way to measure it is say you lay the wheel face down, take a straight edge and lay it along the inner lip, then take a ruler and stand it up on the flat hub meeting surface. the measure ment from the flat surface to your striaght edge is your backspacing.
the smaller the number the farther the wheel will stick out, if you have 4.5" of backspacing the mating surface of the wheel will be 4.5" from the inner lip. a wheel with 6" of backspacing the mating surface will be 6" away from the inner lip therefore making the wheel tuck into the wheel well a little more.
heres a link to a site that explains it.
http://www.getahelmet.com/jeeps/tech/backspace/
Old Feb 27, 2009 | 06:34 PM
and i dont beleive there is a such tire that is made in a 35X12.50X9. i dont know of any 9" wheels out there.
and you cant run any smaller than a 17" wheel on these trucks due to brakes and you cannot use the stock wheels on a 6" ift because they dont have anough backspacing they will rub against the knuckle.
Old Feb 27, 2009 | 06:39 PM
tlt008's Avatar
Listen to Eff One Fifty..........he's right on this one.
Old Feb 27, 2009 | 06:41 PM
Darkyst's Avatar
LOL i didnt know what the last number was so that number i listed was totally made up yea i dont imagine ud find 9 inch wheels on anything bigger then a tricycle
Old Feb 28, 2009 | 03:13 PM
Possibly the 9 is the width of the tire and most recommended wheel width to fit it.
Old Feb 28, 2009 | 04:04 PM
wandell's Avatar
No, in both the the metric and floatation sizing system, the last number is simply the diameter of the wheel.
