Sponsored by: CARiD
6" fabtech lift
Old Feb 24, 2009 | 02:09 PM
easyrydaddw's Avatar
6" fabtech lift
anyone planning on 6" fabtech lift on 2003 screw 4x4?
i'm interested in purchasing your deleted stock parts.
i want to remove my lift, wife and kids having difficulty gettin in and out.
Old Feb 24, 2009 | 03:31 PM
06yz250f's Avatar
what if you let up on you torsion bars to lose some height and put a shorter rear block, and depending how much you can drop it you could run 33's instead of 35's.
Old Feb 24, 2009 | 08:17 PM
MANMAN's Avatar
So are you selling you kit?
Old Feb 25, 2009 | 12:35 AM
Indo's Avatar
Get some side steps or nerf bars.
Old Feb 25, 2009 | 06:34 AM
scootr2200's Avatar
Yeah, holler at me if you're selling that lift. I will definitely consider buying a good condition 6" Fabtech lift.
Mickey
Old Mar 3, 2009 | 11:07 AM
i'll look at the torsion bar and rear block scenario with the step bar, thanks for the suggestions.
if that does not work out i'll consider removing it completely
reference to the wheels, i have 5 hole, so the 6 wont work for me.
Old Mar 3, 2009 | 07:12 PM
06yz250f
how much lowering (inches max) can i expect from torsion bar adjustment?
Old Mar 3, 2009 | 07:26 PM
minimonster17's Avatar
probably an inch or two.
Old Mar 3, 2009 | 08:45 PM
06yz250f's Avatar
Originally Posted by easyrydaddw
06yz250f
i dunno how much you can get from torsion bars but ^^ sounds right. probly get it down to 4" of lift and get nerf bars and your wife should have no trouble at all getting in. i think coobies told me he is expecting 2" drop with his torsion bars
Old Mar 3, 2009 | 09:30 PM
forgot to mention, you can swap in a set of chevy torsion keys to drop the front end a little more. The are indexed differently, and thus allow you to lower the front end down some more, before the bolt is completely backed out of the torsion key.
if you choose to lower the suspension on your truck back to stock, you'll need a set of stock steering knuckles, the stock frame crossmember that also has a differential mount point welded to it, as well as oem length shocks.
Old Mar 8, 2009 | 01:01 PM
ok, here's the deal,
rear presently has 6" lift, 4" block + 2" bump stop
i want to lower the torsion bar to minimum (1 to 2" drop), and replace the rear 4" block with a 2" block + 2" bumpstop (total 4" in the rear). Hopefully to maintain level. I am looking at running a set of Nitto terra grappler (325 65 17's) on my stock wheels.
also looking to add step bar.
does this make sense in terms of what i am trying to achieve. trying to post up some pics, so bare with me.
what are your recommendations on tire size on the stock wheels? i'm looking for that right fit; width, height of tire to complement lift on truck.
all suggestions accepted, considered. thanks
Old Mar 8, 2009 | 01:28 PM
cotedog03's Avatar
A 325/65r17 might be a little wide for a stock rim, depending on the true width of the tire. I would look at a 305/70r17 or a 315/70r17, the first is about 33" tire maybe a little bigger and the second is about a 35" tire, both around 12-12.5" wide.
Old Mar 8, 2009 | 01:32 PM
4.2trimble's Avatar
if you want stock parts ill mail you everything that i have. you pay shipping and they are yours.
i dont need them anymore anyways
Old Mar 8, 2009 | 01:53 PM
here are the pics
Old Mar 8, 2009 | 01:55 PM
4.2trimble's Avatar
nice stang.
now the reason i offered you the stock parts is so you can swap out the lift parts for the time being then when you are able to lift it agian just put your lift back on.
