Finally got my Pro-Comp installed!
yeah dude, with that different photo from the side angle it doesn't look like its squatting much at all... if you want a bigger block, you could check these guys out: http://4wheelonline.com/ProCompFordS...LiftKits.21799
you might want to look under 4wd though, they will have bigger blocks if you want to get up higher... go to the f-series 4wd, then 04-08 f-150 4wd, then 4" lift - under there, they should have 4" and 5.5" blocks for the rear
yea it doesnt squat as much as i thought i would still go with an add a leaf if i were you...different brands lift the truck different amounts but i know pro comp makes a 2" long style for around 100$ and skyjacker makes a short style that lifts 1.5" and all add a leafs will increase your payload
it will keep it the squat to a minimum when towing
yeah that would be sweet! but, I just purchased that grill not too long ago and I need bigger tires first!
Did you not see the other pic I posted? The one you think looks "awful" is from a bad angle...
