Serious Lift Question
yep °°Pat°° , mine is 5.4 4x4....
hmmm , that long travel setup looks great as hell! but now i need to clear my mind about which one i need most , i know am not making my truck a serious dunes runner or hill climb shooter , but each Rize 8in kit and the compagnie kit has it's own pros and cons....interesting....so let's search
What about the Rough Country RCX stuff?
Any word on those kits. They seem to be on Ebay quite a bit and for alot less money as well.
http://cgi.ebay.com/ebaymotors/Rough...Q5fAccessories
I know it is not a necessity to re-gear when lifting, but it is a recommendation. But how much noticeable performance is lost and how much additional strain are you putting on the drive train if you run your stock 3.73's?
This is directed at both 6" and 8" lifts. recommend re-gear for both?
its an 08 f150 HD \
You sure u dont need to regear for 6" on 35's ur the first guy i read that has said that
mana f150
You sound like you're going to use your truck pretty much like me, just a weekend toy. I went with the 6"procomp stage 1 and a 2.5" spacer. 37's fit with ease. It's much cheaper then the Fabtech w/ coilovers and rize. If I had to do it over I'd probably do a Rize though just b/c of the CV angles.
You can regear for 35s. It's not really needed until you get over that. 37's is the size most people talk about regearing.
mana f150
)I guess a long-travel shocks on a 8"lift whould be enought for me
, do they make aftermarket rear shocks? i belive Fox make...any ideas?
When talking about regearing, a lot of people forget that a lot depends on how you use your truck. The two biggest question are how tall of a tire are you using and how do you use your truck. For instance, I have 35's and stock 3.55 gears. I get away with this because it's a daily driver and I never tow/haul anything heavy. If I did, I would have stuck with 33's or regeared.
Most people can get away with 35's and the oem gears but with 37's you need to regear.
, but let's first buy the wheels and lift and see what size he have...i know am getting the biggest ones , but i should know their size to gear it right....and ZeroDormancy , lol let me first finnish mine , then i will do yours
and do you guys know from where i can buy the solid axle swap? i had found few information at this site
http://www.ntwonline.com/
also what do you guys think about this clutch kit? am going to hual 1 quad in the back , but i love horspower
http://cgi.ebay.com/ebaymotors/FORD-...Q5fAccessories
this summer will be very nice! specially when parts starts to arrive!
