Sponsored by: CARiD
RCD Suspension
Old Jan 29, 2009 | 05:52 PM
JFisher08150's Avatar
RCD Suspension
Has anyone had any experience with RCD suspension products? I have an 08 supercrew and am looking to lift 6", I see alot of people are between fabtech and pro comp. Also what kind of back spacing would I need to run with a 6" lift with 35's?
Old Jan 29, 2009 | 09:32 PM
big black beast's Avatar
i just got mine, its a 6" rcd with fox shox all around. so far so good.
Old Jan 29, 2009 | 09:37 PM
06yz250f's Avatar
wheel backspacing, roughly 4 5/8 on a 9" wide wheel i believe is about the recommended by most lift companys. it should be listed on the companies website. obviously you don't have to go by that, just depending on the wheel you might rub a little
Old Jan 29, 2009 | 10:08 PM
wandell's Avatar
RCD makes a great lift. I'd go with a 9 inch wide wheel with 5 inches of backspacing, which is probably the most common spec.
Old Jan 30, 2009 | 12:58 AM
mattd17's Avatar
i love my RCD lift..... it is a very complete lift.... extended brakes lines, biletein shocks on all corners, replaces the rear block with a single 5" block (although it should be about 1/2" taller), great quality(heavy material, looks much better than other brands crossmembers.....
downside...... price. but, you get what you pay for.
when it comes to the wheel specs, they are rather conservative when they rate the lift. you can run larger backspacing if you want, but as wandell said, eventually you will have things rub.
