question about coil spacers and AAL
i have a 2003 f150 2wd with a 7.5 inch fabtech and 3 inch PA body lift. i wana add 1.5 inch coil spacers by daystar and 1.5 inch AAL by fabtech. would that fit my truck and would it be even all around right? any help would be great because i would like to order tomorrow. thanks.
if i go with rear blocks i would just be stacking them on top of the ones i already have correct? would i need to get new u bolts and the screws or would they use the same ones? the same with the AAL they would be stackin on my current ones correct?
Yes, you can add the Daystar spacers. If you don't have them already with your Fabtech lift, I'd install adjustable camber bolts. Some trucks need them to get the alignment within specs, some don't. They are only about $40 so it would be worth it to install them just in case.
Depends on how your rear is lifted now. If you have a block (I wouldn't go larger than 5 inches) , go with a taller block or add-a-leaf. If you already have an aal, I wouldn't add another one.
