Sponsored by: CARiD
Leveling kit and 3" lift spindles on a 02' 2wd?
Old Jan 23, 2009 | 12:37 PM
GaNole07's Avatar
Looking into buying the 3" spindle kit for my truck would i run into any problems with getting it aligned adding a 2" leveling kit to it? or would i even need to get it aligned? neither instructions say.. I'm looking to run some 315/70/16's on 16x10's think they'll fit? also looking at 295-75/16s too, thanks for the help!
Old Jan 23, 2009 | 03:04 PM
wandell's Avatar
Yes, you can combine lift spindles and a leveling kit/coilspring spacers. However, you may need adjustable camber bolts to get the alignment within specs. Some trucks need them, some don't. They are only about $40 so it would be worth it to go ahead and add them. Also, I wouldn't use 10 inch wide wheels with lift spindles. Most lift spindles increase your front track width a few inches which will make 10 inch wide wheels stick way, way outside the wheelwell. You also wouldn't be able to fit 35's using them. 35's will be a tight fit with an 8 inch wide wheel.
Old Jan 23, 2009 | 03:48 PM
madmaxwell87's Avatar
I'm running that setup with a 305/70/16 tire on aftermarket 16*8 wheels. I had to trim a good portion of my front valance to clear the tires. 295/75/16 would probably work good but might require some trimming too.
Old Jan 23, 2009 | 05:58 PM
GaNole07's Avatar
Cool thanks guys, are those 305/70/16's u have on your truck in your pics?? I really like the way it sits
Old Jan 23, 2009 | 06:07 PM
yeah those are them, its still a little tail high with a 3" block so i probably got more like 5"s in the front
Old Jan 23, 2009 | 06:19 PM
GaNole07's Avatar
cool thats what i'm lookin for i probably will too since i got a v6
