01 F150 Front end build...LT
why?????
why not run a n/a 5.4 with the paschal 6.2 stroker kit, some worked heads (2 or 4 valve), cams 42# or 39# injectors, 90mm MAF a 255 oe 325lph in tank pump and a good tune and call it it a day, that way you's still be ford powered and you'd be able to maintain your factory wiring and accessories even though fabrication doesn't appear to be an inssue with you
nice project
why?????
nice project
nice project
But always keep it simple stupid.. K.I.S.S.
the 4r70 is a crappy trans and is the weak link in most projects, i'd just keep a ford engine in it like a 351w based motor or something
anyway, keep us posted on what you do to your truck, it looks like fun
The top and bottom plate are 3/16 cold roll plate, as well as where the upper uniball mounts, and the center section since the hydro bump will bump off that point. The sides and internal gussets are 1/8 mild steel. I love the penetraion lines..kinda makes me want to just clearcoat it. Ha.
I figuered might as well spend the $$$, stopping is kinda important when you need to. And with 37in heavy race tires. but i got a SMOKIN deal on the wilwoods w/ brake pads..pretty much half off and still in boxes.
Ill have more pics wednesday night, the upper is done 100% and we decided to move the lower arm another 1in. forward where the spinlde will meet, to give me some more castor at ride height..i should be at about 5-7 deg. of castor at ride height now. It was at about 3-4.
Changed that in the Jig, and got the uniball cup, and bushings mounted in the jig, drew out the lower on some poster board how i want it, and gonna cut it out of the plate Wedneday. Lowers are gonna be all Tig too. Ha
