Sponsored by: CARiD
u bolt question
Old Jan 20, 2009 | 09:31 PM
floorit's Avatar
u bolt question
im about to install a rough country 6 in life on my truck. i will also be adding a set of 5100' up front. the rough country kits come with the lift block and a AAL for the rear. i want to run 37's so i was think of getting the 5.5 inch block from pro comp for the rear. i need to know it the if the 5.5 block kit from pro cmp comes with longer u bolts ( i dont think it does) if not where can i get a longer set of u bolts. or are to u bolts that come with the RC kit long enough to add the 5 1/2 inch block???
Old Jan 20, 2009 | 10:45 PM
fx4 for life 79's Avatar
the block does not come with u blots, you will have to get new ones
Old Jan 20, 2009 | 10:53 PM
floorit's Avatar
where can i find them? thanks for the help
Old Jan 21, 2009 | 04:27 PM
floorit's Avatar
anyone?????
Old Jan 21, 2009 | 04:37 PM
minimonster17's Avatar
check around locally. there are shops that can make them for you at a reasonable price.
