Sponsored by: CARiD
Shocks Question
Old Jan 11, 2009 | 12:26 AM
MellinColony6's Avatar
Shocks Question
I have an 04 150 Screw, i was thinking of replacing the shocks once i came back from deployment, but i've never really done alot of work on vehicles before. Is it as simple as removing the old one and putting the new ones in? Do i need anything special, i.e. a lift or something, or can i do it while it's on the ground? I appreciate anyone's help. Thanks
Old Jan 11, 2009 | 12:30 AM
thorherc67's Avatar
the rear shocks can be done easily just unbolt then bolt in the new ones.. the front is tricky,
you have to take out the whole shock use a spring compressor take out the inner shock bolt in the new one and put it back together.. to do that you will need to lift up the front end and take the tire off
Old Jan 11, 2009 | 12:54 AM
That seems like a lot of work, especially since i really don't know what I'm doing.
Old Jan 11, 2009 | 08:26 AM
wandell's Avatar
Right, the rear is easy, but the front is more involved due to the coilover shock design.
Old Jan 17, 2009 | 12:44 PM
lewdog99's Avatar
how tricky is it to install new front shocks on a 98 f150 4x4?
