Sponsored by: CARiD
2" AS Leveling kit...
Old Jan 5, 2009 | 10:25 AM
jtarms45's Avatar
Need a little advise on leveling out a "too high in the front now" 08 Lariat. I put a 2" AS leveling kit on it two weeks ago. I was thinking about air bags in the rear or adding leafs. Thoughts, or suggestions? Also, does AS sell rear leafs? I don't need much, my reasoning on this is when I put weight in the bed or hitch, it is going to squat down more. I'm just a little high in the front now, not bad.
Old Jan 5, 2009 | 10:51 AM
brianjwilson's Avatar
Autospring sells a 3" block to replace the stock 1 7/8" block. Disclaimer - I have heard that they crack around the corners in time because they are hollow.
Skyjacker makes 1" and 1.5" 'soft ride' add-a-leafs.
Air bags are good if you haul a bit of weight around. They should not be too stiff if you only leave 10psi or so in them with an empty bed I suppose.
