Sponsored by: CARiD
Replacing Ball Joints
Old Dec 28, 2008 | 02:56 PM
JHens4's Avatar
So I need to replace my ball joints. apparently after 100k they are junk. Are there any tips or tricks to changing these? When i got my fluids flushed the mechanic said i needed them pretty bad, but i dont want to pay $65 an hour on a job i can do myself in the driveway. Ive done ball joints before, but never on 4x4 or a truck for that matter. where should I order them from? Ive seen kits on ebay for roughly 200, but if there is a brand I should look for let me know. Thanks
Old Dec 28, 2008 | 02:57 PM
moog is best brand,
also you will need to rent the ball joint press from your local autozone/orillies
Old Dec 28, 2008 | 08:38 PM
4wd150's Avatar
yes im sure most will agree Moog is the brand to go with
Old Dec 28, 2008 | 08:39 PM
JHens4's Avatar
cool. plannin on replacing them while im on break. hopefully they wont be to bad. last thing i changed ball joints on was an old *** vw bug and it took a torch to get them out
Old Dec 28, 2008 | 09:01 PM
90taz's Avatar
i dont no about 4wheel drives but 2wheel drives requires you to replace the upper control arm for the uppers. the bottoms press in. deffinatly rent the press. it dosen't take long at all.
Old Dec 28, 2008 | 09:04 PM
JHens4's Avatar
from what ive seen the 4wheel drive the upper control arm is going to need to be replaced too
Old Dec 28, 2008 | 09:26 PM
90taz's Avatar
just a note the ball joints and tie rod ends pop out with a few good hits on the steering knuckle no forks or pullers needed. just make sure to hit the knuckl only.
Old Dec 30, 2008 | 06:48 PM
JHens4's Avatar
well i tried to replace one of them today because ive been having a noise coming from the left front. cant get the ball joint to break lose. ended up breaking a hammer trying to get it lose. which really sucks because the hammer hit me in the head and busted me open lol. went and got the forks to try to break it, bent the forks. this bastard is stuck
Old Dec 31, 2008 | 04:36 PM
90taz's Avatar
which ball jiont are you trying to get out. the top one is part of the control arm, and the whole arm has to be replaced. the bottom one has to be pressed out, which you can rent the press from autozone. the only thing you use the hammer on is the steering knuckle which has to be removed first.
