Sponsored by: CARiD
Can i?!?!?
Old Dec 17, 2008 | 07:31 PM
grantoser's Avatar
Question Can I?!?!? HELP!!
Hey PLEASE help.
I need to know if i can run these rims with ONLY a 4 inch lift or could i with a 6inch? ive been told with some 6inch lifts you can run factory backspacing and mine have 6.288?? isnt that pretty close or no? could i get a spacer the fix the problem?
http://aewheel.com/wheels_detail_specs.cfm?id=262 (I HAVE THE 20's)
what lift can i run with these?!
Also would Toyo mt's 35x12.5x20 be too wide for my wheels? thanks for the help!
Old Dec 17, 2008 | 09:14 PM
grantoser's Avatar
Any help out there?
Old Dec 17, 2008 | 09:18 PM
skeeter_usaf's Avatar
Ok first of all that rim is not really designed for a lifted truck. The tire you mentioned is cutting it real close with that narrow of a wheel. All lift companies will give you the right backspacing required for their brand of lift so decide what lift you want and go from there. I would also recommend losing the 3" spacer and going to a 2".
Old Dec 17, 2008 | 11:21 PM
IDNC76's Avatar
i would get new wheels if you can
i had Moto Metal 951's 20x9 with 6.18 backspacing
with Toyo Mt's 35/12.5R20
3in body lift with 2.5 as
i would say there was an inch of clearance between the tire lugs and the upper control arm
and it would rub every time i go into the driveway or turn the wheel full lock.
it was really annoying, and thats not something trimming can take care of lol
also too much backspacing can ruin the look/stance of a lifted truck.
if your keeping those rims, i would def go with a skinner tire, and an A/T and not M/T with large side lugs
also your rims are skinner with more backspacing, so in would be even closer
you can try it, but i would get new wheels if you can
just my 2 cents
Edit: i believe you can run stock specs with the rancho lift
Old Dec 17, 2008 | 11:45 PM
grantoser's Avatar
alrighty well that sucks.. lol. idk i guess ill have to pass on the lift. Cant afford lift, tires, AND rims. O well tho. Thanks for the help! looks like i might go and get a aal kit to get as much as i can... haha.
Old Dec 17, 2008 | 11:58 PM
IDNC76's Avatar
yeah, start savin ,or downsize and switch over to some black rims
then powder coat your bumpers white and get rid of the chrome
Old Dec 18, 2008 | 12:07 AM
grantoser's Avatar
haha yeah they would be easier to keep clean thats for sure! :P youve got a sweet looking set up man.
do you know anything about aals? i have a 3 inch leveling kit in the front and it looks level from the tire to the top of the fender but the VERY back by the trailer hitch sits really low.. :S it looks really tall from the front coming down the road but almost shorter than stock from the back even tho the fender to tire heights are the same... would a 1.5 inch all fix this problem?
Old Dec 18, 2008 | 05:46 PM
RJcavF150's Avatar
yes, it will.
It's not hard to install, and it will give you the added height you want!
You'll have a factory stance again, just higher, you'll have the rake but who cares.
Old Dec 18, 2008 | 05:54 PM
Eff One Fifty's Avatar
i must of missed out on something when i installed my AAL, taking those clips off was a pain in the ***, so was taking the center pins out.
But the AAL will give you the height you want.
those wheels wont look that good with a lift either because the truck will look to tall and not wide enough with the bad backspacing..
Old Dec 18, 2008 | 08:26 PM
str8t six's Avatar
whats wrong with him running that wheel and tire combo? people run 35's with stock 7" wide wheels all the time.
Old Dec 18, 2008 | 08:57 PM
IDNC76's Avatar
with a 6 inch lift ???
Old Dec 18, 2008 | 09:09 PM
ride_002000's Avatar
Eff one fifty and IDNC76 what is the back spacing on your rims?
Old Dec 18, 2008 | 09:10 PM
IDNC76's Avatar
mine are 20x9.5 with 5.25 backspacing
and
Eff one Fiffty's are 20x10 with 4.5 backspacing
Old Dec 18, 2008 | 09:16 PM
Thanks, I think im going to probably go with a 5" BS on 18x9 rims when I get rims. Seems to be happy medium with 5". does this sound about right? or maybe a 4.5" bs.
str8t six's Avatar
i dont know much about the 04+ trucks, but why couldnt he with a 6" lift?
