lift kit / wheel question
Do lift kits place the spindle (correct descrip?) at the same depth in the wheel well as stock suspension? I know it can't be far off if any.
In other words, will stock wheels on a 6" fabtech lift, stick out of the fender well any farther than stock ?
all the lift kits for 04-08 push the front tires out further, only way to make it look "normal' are to run spacers in the back. my rancho pushed the tires out, 2 inches or so, pro comp and fabtech push them out even further.
FWIW superlift kits do not increase track width. my rear tires stick out just as far as the front.
Fabtech says track width is not increased . .
. . . well the thickness of a Roosevelt . . . so what's up with this ??
I just called Fabtech and was told that the width or track of some kits is made wider than oem, but for an 04' and later f150, it's minimal "like the thickness of a dime" I was told.
So . . . what do you make of that after some of the above comments ?
and then have to buy 20x9's rather than 20x10's
Update - from Fabtech, for the record . . .
since my previous post above, I had to believe Fabtech was mistaken on their comment that the track width is not increased more than the width of a dime with their 6" lift kit.
I just called the factory back and asked again. After Josh inquired with tech, he said the width is bumped out approx 1" on ea side for an '06 - so overall 2" wider track.
