Sponsored by: CARiD
leveling kits
Old Nov 29, 2008 | 09:20 PM
31cc's Avatar
leveling kits
I have seen ads for leveling kits made of steel, aluminum, and polyurethane , what are the advantage/disadvantage to these different materials. anyone had problems with squeeks, cracking or anything else?
Old Nov 29, 2008 | 09:33 PM
johnnyd2723's Avatar
I had the aluminum spacer kit from Summit Racing installed for almost three years. Removed it and it was in perfect shape. Now I have the AS lift installed which is steel. So far so good.
Old Nov 29, 2008 | 09:50 PM
wandell's Avatar
There are no advantages. It's just marketing gimmicks. I'd go with the Autospring kit. It is cheap, well made and just plain works.
Old Nov 29, 2008 | 10:06 PM
31cc's Avatar
thanks for the replies, still havent decided if I want a 2" or 2.5" kit. anyone had trouble with front end components wearing out with the 2.5" kits (ball joints or cv joints)
Old Nov 29, 2008 | 11:50 PM
mhockey9090's Avatar
I put a 2" AS on my truck and have off road it pretty hard several times and have not had a problem yet . Now im not sure how much worse the 2.5 will be on your truck but a lot of guys here have either and dont seem to have a problem yet. Ive had mine on my truck for about 1 1/2 years.
Old Nov 30, 2008 | 09:25 AM
BlkButy's Avatar
I don't know the validity of this but I was told to only use a 2" AS on a 4x2. Unless you plan to raise the rear. Is this a true statement?
Old Nov 30, 2008 | 10:36 AM
If you dont plan to raise the rear any yes. Well even then you should have the rear raised a bit, with the 2" 4wd lift blocks. The front may still be a little bit higher with the stock 2wd rear height.
Old Nov 30, 2008 | 08:45 PM
Fifty150's Avatar
Not true at all. An add-a-leaf will work fine with any brand of leveling kit. Just remember that once you add a kit, your truck is leveled. If you raise the rear, then you're right back to the front end being lower and the rear end being higher.
Old Nov 30, 2008 | 08:48 PM
BlkButy's Avatar
Should I go with the 2" or 2.5" AS?
Old Nov 30, 2008 | 08:51 PM
On a 4x2 go with a 2"
Old Nov 30, 2008 | 08:53 PM
Fifty150's Avatar
My own story is bass-ackwards. I wanted an add-a-leaf for a stiffer rear end and a little increased load capacity. My truck would have been just ridiculous with the rear end being 2 more inches higher in the rear than stock, and the front end almost touching the ground like a low rider. All that the leveling kit did for me was bring me back to an angled rake. I had a 2.5" kit and it was fine.
