Sponsored by: CARiD
front end clunking
Old Nov 22, 2008 | 06:59 AM
keith97xlt's Avatar
front end clunking
ive got a 01 250 that when i turn the wheels. all the the way left or right ..lock to lock i get a clunking noise. almost sounds like something is hitting the floorboard. the ball joints are new the dealer replaced those right before i got it. its fine otherwise smooth on the highway..steering is tight. any help would be appreciated. o yea..it is a 4wd also.
Old Nov 22, 2008 | 09:23 PM
fasteddy250f's Avatar
does it have a lift? I had the same problem after I did my lift it sounds like the track bar that mounts to the front axle.
Old Nov 23, 2008 | 05:31 AM
keith97xlt's Avatar
no its 100% stock.
Old Nov 23, 2008 | 08:24 PM
hmm you might check the sway bar end link make sure there tight you may even have to add a washer. Hope this helps...
Old Nov 23, 2008 | 11:55 PM
mhockey9090's Avatar
cv joints going bad? I heard clunking in mine took it too ford and think they replaced the cv joints and havent heard it
Old Nov 24, 2008 | 12:03 AM
4.2trimble's Avatar
ball joints, tie rods, drag links, sway bar links check all that. Our work SD did this and all this was replaced. Now the clunk is gone
