Sponsored by: CARiD
help with body lift
Old Oct 21, 2008 | 10:41 PM
2wd98f150's Avatar
help with body lift
i have a 98 2wd f150 ext. cab. i was going to get a leveling kit but that isn't enough so i want to go with a body lift.
i'm either going with 2 or 3 inches obviously so what tires an i fit with either one of those lifts?
will anything be affected in a bad way with a body lift?
Old Oct 21, 2008 | 10:47 PM
minimonster17's Avatar
i'm not sure on a tire size on a 2WD, but i would get the leveling kit as well. you will not "mess" anything up with the body lift, as long as you perform the install correctly. read and reread the instructions. on a '98, expect to fight the body bolts every turn out, with all the rust and crud of ten years holding them in the bushings. fyi, there are 14 bolts total on an extended cab. make sure to install all of the extensions as well, steering shaft, gas lines, etc. the kit includes everything you'll need.
Old Oct 21, 2008 | 10:56 PM
2wd98f150's Avatar
i plan on getting new tires down the rode but wont be able to afford them right when i get the lift. if i get a 3in body lift will the 29 in tires look real goofy?
Old Oct 21, 2008 | 10:58 PM
06yz250f's Avatar
won't look great, but wont look terrible. do the leveling kit as well
wandell's Avatar
29's will look a little goofy. If you add a body lift and a leveling kit you can fit up to a 33x12.50 tire.
Old Oct 21, 2008 | 11:01 PM
2wd98f150's Avatar
well that is what i want to fit is 33 12.50s
well if i get the money to do the lift and leveling kit for xmas then i'll have to wait until my birthday in april to get the tires probably.
does anyone know where i can get a picture of a 2wd with a 2-3in body?
