Sponsored by: CARiD
8" Rize Lift problem
Old Oct 21, 2008 | 05:22 PM
headbrake's Avatar
I just put an 8" Rize Lift on my F-150 and my problem is the back end is dumping and not level. I had bought 2" add a leafs how ever the install garage didn't add them when kit installed. will the kit settle and level out? Or should i have them add the leafs? Any help and/or advice would be great.
Thanks in advance.
Old Oct 21, 2008 | 05:35 PM
06yz250f's Avatar
if you want level the AAL will need to be installed. the front end will not drop.
Old Oct 21, 2008 | 06:33 PM
neuspeed5's Avatar
Yep, throw those leafs in. The front is not going to settle.
Old Oct 21, 2008 | 06:41 PM
mxrider38's Avatar
Yeah I put the aal in my truck also.
Old Oct 21, 2008 | 08:39 PM
djh1121's Avatar
http://www.deaverspring.com/products/leafsfd.html
Old Oct 21, 2008 | 10:16 PM
FX4life's Avatar
you will need the aal. Unless you want the deavers like mentioned above, ive got um
Old Oct 21, 2008 | 10:23 PM
chiefFX4's Avatar
i noticed they only make them for 2wd applications. since they are a 6" lift for a 2wd truck, does that mean theyll level my 4wd truck since it had the 2" block from factory?
Old Oct 22, 2008 | 01:25 PM
headbrake's Avatar
Thanks everyone! I will have them add the 2" AAL
