Sponsored by: CARiD
Where does the coil spacer go?
Old Oct 20, 2008 | 11:22 PM
Westcoast4121's Avatar
Arrow Where does the coil spacer go?
Where does the coil spacer go and how does it work? How much does it lift?
Old Oct 20, 2008 | 11:37 PM
alomar's Avatar
There are a few different sizes available, but most common is the 1.5"-2". If its a daystar coil spacer it goes on top of the coil spring. SKG makes one that goes on the bottom.
Old Oct 20, 2008 | 11:47 PM
Fifty150's Avatar
It goes into the coil spring. The amount of lift depends on which model you buy.
Old Oct 21, 2008 | 12:27 AM
alomar's Avatar
^ on a NBS yes, his info says a 02
Old Nov 7, 2008 | 04:33 PM
Hess10's Avatar
i plan on doing the same to my 99 2wd supercab. the spacer still goes on top between the coil and the spring plate correct? do i have to pull the spindle to get to the coil (i know just one ball joint if i have to)
thanks
