Suspension question???
i got two questions
1) i dont want a huge lift i just want to raise my truck a few inches. should i get a lift kit or is there a cheapier way to lift my truck??
2) is the lift going to mess with my fuel mileage??
tire tilt? are you talking about it being 2-2 1/2" lower in the front than the rear? thats how all trucks come from the factory. a 2 or 2 1/2" leveling kit will fix these problems for you. about $80 for the kit shipped. install is simple. and then you will need an alignment. Max tire size for a 2x4 will be a 33/12.50 on stock wheels
no it was lowered cause i've pulled up next to other f150 and none of them are as low as mine.
I think he means tire tilt as in the top of the tires are farther in than the bottom. Like it gets on lowered trucks. If its been lowered it was done cheaply. But it sounds to me like it needs lined up.
ya, just looks at your shocks and see if their oem or not and check your coils as well. most likely your just 2x4 and your truck naturally sits low. your shocks could also be bad.
rancho makes quick adjust shocks. bilstein makes adjustable shocks. or you can also use a 2"-2 1/2" spacer
BIGKEV
thats exactly what i mean the top of my tire tilt in further than the bottom.
one of the reasons i kno is because i' just replaced my tires and the in side the side that faces the motor was down to the wire (literally).
