Sponsored by: CARiD
more lift
Old Sep 28, 2008 | 07:49 PM
valleyfreak45's Avatar
more lift
i have a leveling kit on but want a little more....
would bigger tires lift it more, if so how much? 33" tires
and also maybe considering 3 inch body lift with 35" tires? how much higher would it sit?
Old Sep 28, 2008 | 07:53 PM
4.2trimble's Avatar
tires will lift it more but not much. just take your current tires and subtract those from the size you want to go to then divide the number you get in half and thats the lift you will recieve from tires!
Old Sep 28, 2008 | 07:55 PM
thanks
is a body lift really that hard to put on yourself or just time consuming?
Old Sep 28, 2008 | 10:26 PM
wandell's Avatar
We could give you better advise if we knew what kind of truck you have.
Old Sep 28, 2008 | 10:32 PM
06yz250f's Avatar
well since we dont know your truck ill just tell you for both.
97-03= most people recommend doing it yourself not to hard.
04-08= PITA. have it installed or just get a suspension lift and install yourself.
suspension is probly easier than a body lift on the new body style. can get a pro comp stage I for 1100 bucks.
Old Sep 28, 2008 | 11:00 PM
mattd17's Avatar
what makes the bodly lift so much harder for the 04-08's?
Old Sep 28, 2008 | 11:03 PM
sorry guys I have an 04 new body extended cab and 2wd so I don't exactly want 6 inch lift
Just thinking about 3 inch with 35s
And idea of estimated price for body lift and new 35s
Old Sep 28, 2008 | 11:06 PM
06yz250f's Avatar
about a 800-1000 for body lift installed.
tires just depends what size rims.
17" km2 in 35/12.5/17 are 250 a piece
17" BFG AT/KO 240 a piece
your looking about 2k most likely for everything
Old Sep 28, 2008 | 11:07 PM
mattd17's Avatar
km2's in 35x12.5x17 right now are EXTREMELY HARD to find !!! i was told by several vendors that the earliest would possibly be mid December before they were available.
Old Sep 28, 2008 | 11:35 PM
f1504wd's Avatar
Is there any other way to raise front end of a 05F150 Screw without a complete lift and spacers?
Old Sep 29, 2008 | 12:01 AM
Haul 1500lbs in the bed to make the back match the front. In general terms, nope, you need to level it.
Old Sep 30, 2008 | 07:19 PM
f1504wd's Avatar
well how about a leveling kit on a 04-08. when you put that on is there any other way to lift the front without a complete suspension.
Old Sep 30, 2008 | 07:45 PM
minimonster17's Avatar
no, aside a body lift, or a susp. lift, there's no other way to lift the front end... this ain't cheap, if it was everyone would drive a lifted truck... going from a 32'' to a 35'' tire will lift the truck 1.5'' higher off the ground, but the fender will be packed tight, and you'll probably be in for some rubbin'! you'll need at least a leveling kit to stuff 'em in there like that. don't go over a 2'' leveling kit, or your front end will wear much faster.
the reason why the body lift is such a PITA on the 04-08 is b/c you have to replace all the body bushings along w/ the new bolts and spacer blocks.
on the 97-03, the stock bushings are retained w/ the new bolts and spacer blocks, hence it being "easier."
Old Oct 1, 2008 | 08:56 PM
f1504wd's Avatar
WEll i guess im gonna have to level it out and put some 305's on it
