Ball joint problems already
2 weekends ago, my truck started making this horrible squeeking noise in the front. I was embarassed driving it because it sounded so bad. I made sure everything on the front end was tight where it was coming from. After that I injected grease into the balljoint boots with a needle that fits on the end of a grease gun. The squeek was still there so I was getting ready to bring it to a front end shop the next day. The next day.........the squeek is gone. I bought the truck brand new 2.5 years ago. I don't know if they are supposed to be greased every so often or not; but i'm pretty much convinced it's due to the level kit. Just wanted to share this and was curious if anyone else is having balljoint issues yet.
probably within the next week im replacing everything in the front end. Tie rods, tie rod ends, OE upper control arms with Camburgs, lower ball joints, and stabilizer links. Ive got a hideous clunk and im tired of it, if that does not solve it lets hope the kings do...
Should i go for regular ball joints or greasable ball joints?
The same thing happened to me around 60,000k on my 04+ and my mechanic said the ball joints that Ford uses are not that great of quality and have been known to be problematic.
Moog
2nd that...get the HD version if available but even the non-HD's were beefier than OEM (at least for my '95 Tahoe).
I think I am heading in this direction myself before things go bad (~30k mi).
I was going to get the greaseable ones off summit but i just went ahead and ordered some HD spicers from rockauto.com, also picked up sway bar links and bushings, and tie rod ends. If yall could not tell im tired of the constant rattle on rough roads and the clunk when turning...
Same problem!
I am going through the same hassle you are right now. I had my lower ball joint replaced by ntb about six months ago, and it has started to squeak horribly!! I refuse to drive it around like that. I went to ntb so they could look at it, and when they expected it they of course found nothing wrong. When the guy checked it with a pry bar he believes it "set" itself back in, and the squak was gone. I drove it 120 miles yesterday, and low and behold the squeak was back. I went and bought a new grease fitting, because the injection needle wasnt cuttin" it. I greased the holy daylights out of it, and there is no more squeak for now.
does anyone even make greaseable ball joints and tie rods for the 04+ models for sure???
i looked EVERYWHERE when i put my lift on a year ago because i hate this "greased for life" crap but could'nt find any. My local ford dealer i called told me no one makes anything else for them.
