Sponsored by: CARiD
Leveling kit
Old Sep 18, 2008 | 07:40 PM
newbieford's Avatar
Leveling kit
Just installed my leveling kit, what a difference it looks really good!
Old Sep 18, 2008 | 07:48 PM
08Ford FX2's Avatar
Any pics.
Old Sep 18, 2008 | 08:31 PM
tr3b's Avatar
did you go with the 2.5' AS?
Old Sep 18, 2008 | 09:38 PM
newbieford's Avatar
I have pics, but I don't know how to post them!
I use the 2.5 kit from Rough Country they say it's a 3hr job I think I blew it out in about 1 to 1 1/2half hours!
Old Sep 18, 2008 | 09:41 PM
MikeSwt's Avatar
Sign up for a free account on like photobucketdotcom and upload the pictures there. On the bottom of the picture you will see several code options - Just copy the "IMG" one and paste it into your post
Old Sep 18, 2008 | 09:43 PM
CC 08 FX4's Avatar
Then can you put up a step by step guide?? I don't have an install guide for mine!!
Mine are NCD though.
Old Sep 18, 2008 | 09:49 PM
newbieford's Avatar
Do you have a fax there at my shop will fax them to you in the morning if you want other wise i will just tell you!
Old Sep 18, 2008 | 09:57 PM
newbieford's Avatar
1- Remove front tires
2- Just loosen nut on sway bar both sides
3- Remove upper nut on spindle and separate from upper control arm
4- Remove lower bolt from coil over
5- Remove 3 upper bolt from top of strut
6- Slide the coil over down between the tie rod and lower control arm them pull out and up
7- Install your 2.5 kit on top off coil over with lock tight and torque to 35lbs
8- Reinstall top first then slid the bottom into place you may have to finesse a little!
Old Sep 19, 2008 | 05:10 AM
08Ford FX2's Avatar
Old Sep 19, 2008 | 01:04 PM
Easy way to make these truck's look better, now for some larger tires!
Old Sep 19, 2008 | 01:08 PM
hivoltagefx4's Avatar
We want pics man!
Old Sep 19, 2008 | 05:53 PM
newbieford's Avatar
I'm trying!!!
Old Sep 19, 2008 | 06:05 PM
newbieford's Avatar
[IMG]http://tinypic.com/view.php?pic=s1pwsm&s=4[/IMG]
Hows this!
Old Sep 19, 2008 | 09:33 PM
newbieford's Avatar
Can i send these pics to someone so they can post them I cant seem to do it!!!
Old Sep 20, 2008 | 12:32 AM
DARK KNIGHT08's Avatar
Looks great!!
