Sponsored by: CARiD
take out bottom leaf to lower?
Old Sep 18, 2008 | 09:30 PM
cheesepuff1's Avatar
i just put 2" drop shackles on my 2004 screw and it dropped it bout 2" but need bout 2" more...when i had a s-10 years ago i took out the bottom thick leaf spring and it dropped 2" inches or so... has anyone tried this on there truck? i have a total of 4 leafs and dont haul anything with truck.. really tight on budget, just curious.. thanx guys
Old Sep 18, 2008 | 09:37 PM
noblem's Avatar
I dont personally know if i would try it. But if you dont haul anything at all it might be possible but it might bottom out real easy
Old Sep 19, 2008 | 10:28 AM
06yz250f's Avatar
my friend had a 1990 1500 w/ a few inch drop (dont remember exactly) but he pulled one out. he had no problems using it like that. but i wouldnt pull out more than one.
Old Sep 19, 2008 | 06:21 PM
yes the very bottom one (shorter) spring is the overload spring. Its about 3/4" thick and will drop you that much. you will need to put a shorter bolt through the leaf pack to clear the perch on top.
Removing the spring will, soften the ride slightly, and reduce payload, and should NEVER be overloaded without it, or you can cause major spring damage.
BTW i have mine out (03 F150), took my buddies out of his 04 dodge ram, and took them out of Jwool15's 05 F150
Old Sep 19, 2008 | 10:07 PM
ok thanx you guys for answering...will take it out and see what happens... thanx again
Old Sep 20, 2008 | 09:47 AM
were u able to use the factory u-bolts after taking leaf out? adn do u have any tips on easy way to do it? thanx any info will help, its been a long time since i took leafs out of truck,,,
