Sponsored by: CARiD
3 in body lift
Old Aug 21, 2008 | 08:07 PM
Green_Machine's Avatar
3 in body lift
Guys I want to purchase a 3in body lift for my truck....have any ideas where they are the cheapest/ best...?????
Old Aug 21, 2008 | 08:20 PM
minimonster17's Avatar
Performance Accessories makes the kit for our trucks.
Old Aug 21, 2008 | 08:24 PM
cotedog03's Avatar
check out sportztrailers.com, or PM crash lucky13. thats where i got mine, they have the best price by far for our trucks at $160 shipped, which is about 20 or 30 dollars cheaper than anyone else.
Old Aug 21, 2008 | 08:50 PM
Fifty150's Avatar
But body lifts aren't great if you crash your truck.
Old Aug 21, 2008 | 08:53 PM
doubleplayer's Avatar
nothing is, haha
But to the op performance accesories is the best IMO.
Old Aug 21, 2008 | 09:03 PM
_cashel's Avatar
If you crash your truck that hard, I'd say you've got other thing to worry about
Old Aug 21, 2008 | 09:16 PM
bullsh*t! wandell personally saw a 97 on a body lift that bent its frame by driving into a tree. the frame had to be replaced. all of the spacer blocks were intact, and still fastened down by the kit body bolts. if there is a single person whose advice i would trust concerning lift advice on this site, it would be wandell.
Old Aug 21, 2008 | 09:20 PM
here is that thread i alluded to: https://www.f150online.com/forums/su...ift-broke.html
Old Aug 21, 2008 | 09:33 PM
Fifty150's Avatar
Just to keep stirring the pot & fanning the flame:
I still like suspension lifts over body lifts.
Old Aug 21, 2008 | 09:55 PM
i prefer suspension lifts as well, and yet i still have a body lift. a body lift raises the body off the frame 3'', you only gain clearance in the wheelwells, and a little under the axles from the oversize tires. whereas a suspension lift raises the body, frame, engine, transmission, etc, and provides more true clearance. offroad, a suspension lift would be preferred for this reason.
bear in mind, that the only reliable way of lifting a 97-03 enough to clear 37-38's while retaining the torsion bar based IFS is by stacking the body and suspension lift. it is not like the coilover based IFS of the 04-08, in which reliable 8''+ suspension lifts are available. a bit OT, but, under no means is a properly installed body lift unsafe.
Old Aug 21, 2008 | 10:49 PM
wandell's Avatar
I do too. If money was not an issue I'd have a 6 inch Fabtech along with my body lift and some 37's.
Old Aug 22, 2008 | 07:15 AM
Thanks guys! IS there any difference between a 97-02 body lift and a 03 body lift???
I will prob just run 33's maybe 35's. I went yesterday to get my Torsion bars cranked so it wouldlevel my truck, and the guys told me I didn't have torsion bars. IS this right or do I need coil spacers??
Old Aug 22, 2008 | 09:15 AM
06yz250f's Avatar
is your truck 2wd or 4wd? my 02 2wd did not have them. my friends 4wd did tho
Old Aug 22, 2008 | 09:18 AM
_cashel's Avatar
97 - 03 2WD trucks had coil springs and the 4WD trucks had torsion bars
edit: and no there probably isn't any difference in the body lifts. If there is, it's minor. I installed a body lift I had ordered for my 2000 2WD extended cab on my 2001 4WD supercrew without any problems.
Old Aug 22, 2008 | 09:26 AM
ITS AN 03 4WD. SO I GUESS A 02 3IN BODY LIFT WILL FIT MY TRUCK..... SO WITH IT LEVELED AND A 3IN BL WHAT SIZE TIRE WILL LOOK GOOD. i dont want to much of a gap and i dont want it to see crowded..
