need help dropping front diff
Sounds like you got it out? If things aren't lining up, you may need to use a floor jack to simulate the ground ie get it to line up under pressure. Make sure your bolts are all loose! Also, it won't line up perfeclty, but close enough that the alignment show will be able to adjust the rest.
the subframe holes wont line up to the old a-arm holes. i trimmed the piece and nothing, wont fit no way no how! i dont wanna egg the holes out more, they are sending me a new subframe to try.
how the hell do i get that upper diff bolt out?
