Few Questions about Leveling 2002 SCREW
I have a 2002 Supercrew and I want to to either put on a leveling kit or tighten the torsion(sp) bars.
What leveling kit would you recommend? What size?
What are the advantages of a leveling kit over just tightening the torsion bars?
I don't know much about suspension so your guys help would be appreciated!
you wont need to waste money on the leveling kits, its going to let you raise the front of your truck too much, causing premature wear on the boots, axles, and balljoints on the front of your truck. You can easily level the truck by jacking the front end up off the ground so that the suspension is hanging free, and then crank your torsion bars up an even number of turns. Once you get it to the height you want, take it in for an alignment
Thanks for the reply.
