2006 SCREW 4WD 6" Fabtech Lift Q
Old 03-13-2008, 11:40 AM
CHUCKO1404's Avatar
I am going to get the 6" basic kit with a 2" daystar spacer in the front and the 5" block and 2" aal in the rear. My question is can I fit the 355/60/20 Nitto Tera's and not have to regear, or should I stay with the 325/60/20's. Want to know the pro's and con's of going with the 2 sizes.
Thanks for the help.
Old 03-13-2008, 12:21 PM
bigrigpapa's Avatar
If you run the 355's you should regear. That is about a 36.8x14 tire and your truck will be pretty sluggish. The 325 would be about the max without a regear but you wouldn't need the extra spacers or the large block on the rear either.
Old 03-13-2008, 12:41 PM
Boatboy1069's Avatar
Stick with the 325's any bigger and you start really exponentially adding stress to the suspension (ball joints, etc.). You don't have to regear with these tires but i still would if i could! If you want that much lift have you looked into a "rize lift kit"? They come in 8" or 12" lifts" Hope that helps!
Old 03-13-2008, 12:54 PM
wandell's Avatar
I agree.
Old 03-13-2008, 01:47 PM
mSaLL150's Avatar
get a Rize or CST and keep your factory angles.
Quick Reply: 2006 SCREW 4WD 6" Fabtech Lift Q
