Sponsored by: CARiD
Pro Comp Lift on the way
Old Mar 6, 2008 | 01:11 PM
rob2534's Avatar
i had a question for you guys with any 6" lifts. if i add a 2-2.5" spacer to my 6" pro comp, will i need any extenders (ie. steering linkages)? thanks for the help!
Old Mar 6, 2008 | 01:52 PM
st1nn3tt's Avatar
Yes I would assume so. When I was installing my 6'' Pro Comp Lift everything was stretched to the max, so a 2.5'' spacer would probably require linkages.
Old Mar 6, 2008 | 01:58 PM
Shepard69's Avatar
I assume you are talking new body style 04+
Not sure about any extenders, but you can't add and other spacer unless you got the coil overs with the lift. (The package come with a 6" spacer) You will likely also find the back sits lower than front. Order the add a leaf as well. I just had my springs re-arched and a new leaf added.
Old Mar 6, 2008 | 02:06 PM
Jditta's Avatar
You CAN use the adjustable bilsteins up front with the spacer. Thats what I have and I didnt add any extenders or linkages.
Old Mar 6, 2008 | 08:13 PM
Yamaha YZ 250's Avatar
You can stack the spacers too, technically. Its just not a good idea.
The spacers when stacked, the UCA hits on the side of spacer when its at full suspension drop, like when on a lift or when you jump something. Also it puts your ball joints and CV joints at not so good angles.
But I had 6 inch pro comp, with 2.5 spacer for about 50 miles before I took it out cause I was afraid to use 4wd with me angles as intense as they were.
