Sponsored by: CARiD
Lower Ball Joints
Old Feb 28, 2008 | 11:32 AM
MercedesTech's Avatar
Originally Posted by 051fdrof
Maybe in a perfect world, but my right toe was off 3/4" of a degree after my Quick Lift install and I was using the same UCAs. It was enough to notice a pull.
Check out the other thread and see of you can answer his question.
quicklift = change in suspension geometry.
New UCA= same suspension geometry with a new, beefier part.
Like I said, you shouldn't have to. The alignment is taken care of with little "washer" type devices in the lower control arm. The UCA should not affect it.
Old Feb 28, 2008 | 12:45 PM
051fdrof's Avatar
Makes sense
Old Feb 28, 2008 | 01:02 PM
benjaminh98's Avatar
The mechanic said he could barely get it aligned back to factory specs due to the upper ball joint going bad. Is that true or was he stretching the truth a little?
Old Feb 28, 2008 | 01:05 PM
FORDfx404's Avatar
Yeaa, I just changed my lower ball joints and I got 45,000 miles on the odometer on my 04 f150
Old Feb 28, 2008 | 01:48 PM
The upper ball joints, if they go bad, can cause alignment issues. Thats because they get "sloppy" and can't hold their "position". They can allow for other suspension parts to move just a little bit, causing a mis-alignment. When you took it in, was is pulling off to a side ? Thats usually a good sign you may be in need of an alignment.
Hard to tell if he was "stertching" the truth tho... they could have been fine. I didn't see them.
Old Feb 28, 2008 | 06:53 PM
It didn't pull at all. There was significant outer edge wear on both front tires, though. That was the reason for the new tires.
Now, that I think about it. The truck did have a good bit of lane wander on top of the tire wear. I will probably just change both uppers and lowers at the same time.
Damn, that makes for a long Saturday.
at our DIY auto shop:
oil change
brake pad change
upper/lower ball joint change
then off to the shop for an alignment
fun times..
Old Feb 28, 2008 | 06:57 PM
^^^ sounds like a day FULL of excitement ! And you know everything will come together without a hitch
And from the sounds of it, you were probably due for those Upper ball joints.
so you guys have a local DIY shop ? How does that work ? You rent a bay ? never heard of that, but sounds like a great idea... maybe a new business venture !
Old Feb 28, 2008 | 07:03 PM
I work as a contractor on the military base out this way. They have a DYI shop. You can do damn near anything you would ever want to in there. Engine swaps, turn rotors, oil change, tranny change, rear end work, suspension work..I know the hobby shop in Pearl Harbor even had a paint booth.
Old Feb 28, 2008 | 07:11 PM
aww.... didn't know you were on a military base. I knew they had stuff like that. Awesome man, so what kind of work do you do on base ?
Which base?
Old Feb 29, 2008 | 12:08 AM
Ballin STX's Avatar
I have a question, Is there a way to tell your self if your ball joints are going bad??
My second question is if I replace the ball joints with aftermarket ones or beefier ones, will they last longer?
dont mean to jack thread, just was curious, I have a AS 21/2" right now.
Old Feb 29, 2008 | 11:57 AM
Which base?
Port Hueneme. Its helps on the labor costs..
Old Feb 29, 2008 | 12:02 PM
The way to check ball joints, from my recent searching:
1. lift truck up using frame as support
2. place long sturdy bar under tire..bar acts like a lever to lift/move tire..
3. look to see where, if any, the excess movement in the ball jionts is coming from..
if that is wrong, feel free to correct it/me..
I can't seem to find any aftermarket uppers for the 05 anywhere. All I can find is the OEM replacements. I wouldn't mind using MOOG, but finding them is proving impossible.
Old Feb 29, 2008 | 12:54 PM
^^ thats about right, but its reall not an exact sceince. If you start having your truck wander on you, or pull to one side, you may want to look into it. Otherwise the "bar test" would work fine. Also, visual inspections don't hurt !
Old Feb 29, 2008 | 12:59 PM
051fdrof's Avatar
Camburg and Total Chaos make awesome UCAs with uniballs, but factory backspacing won't work. You need 5" max with Camburg and 4.5" max with TC.
Sux
Old Feb 29, 2008 | 02:03 PM
Sux
Does that mean we, 04+ models, have to use oem upper control arms when using oem wheels?
