Sponsored by: CARiD
Body Lift install
Old Feb 2, 2008 | 11:52 PM
eliminate's Avatar
Body Lift install
Well I started the install this weekend and I'm having problems with one of the bed bolts. The middle bolt stripped the torque head. What has everyone founf to be the easiest way to remove one like this. I don't have a torch set either
Old Feb 3, 2008 | 08:06 AM
Kevin24's Avatar
That sucks!!!!
I would say to grind the head off with a grinder.
Old Feb 3, 2008 | 09:07 AM
jk007's Avatar
Originally Posted by Kevin24
That sucks!!!!
x2 - That's probably your best bet. We had to grind 4 of them off on one Install I did. Everything else is just going to be a waste of time IMO...
Old Feb 3, 2008 | 09:20 AM
f150 rider's Avatar
x3-Jk`s the king when it comes to body lifts!
Old Feb 3, 2008 | 09:39 AM
eliminate's Avatar
guess i be running a grinder on it then. get it done early enough maybe i can start on the suspension lift.
Old Feb 3, 2008 | 02:43 PM
glasco's Avatar
good luck can't wait to see it done
Old Feb 3, 2008 | 09:47 PM
eliminate's Avatar
just as i thought everything was going good on the body lift after the bed bolt. I broke off the 2 front bolts too. Still trying to figure out how to get those out. I did get truck lifted up with body lift but still need those bolts removed.
Any ideas on best way to remove the or just but part of the bushing shaft off that has the threads in it.
Old Feb 4, 2008 | 10:25 PM
97f1fifty's Avatar
When you get the chance you need to post some pics of the progress, lets see how its goin!
Old Feb 4, 2008 | 11:47 PM
eliminate's Avatar
I will post some pics tomorrow evening. I had to cut the front mounts almost in half to get bolt out. but it fixed now. Trying to figure out the part is saying to cut the frame in the fron to mount the front bumper now. I will get some pics as it sits and however it sits when i finished tomorrow. Hopefully I can finish the few bolts tomorrow on the frame and get everything together.
Old Feb 4, 2008 | 11:51 PM
Jditta's Avatar
Any updates??
Old Feb 4, 2008 | 11:56 PM
eliminate's Avatar
the rear of truck is back together. the vent line for fuel tank is way to big. front is saying to but part of frame so i'm trying to figure out how I'm going to do that. I will post some pics when i get back to it tomorrow.
Old Feb 5, 2008 | 07:24 AM
JT's F-150's Avatar
Sounds like you are coming along. I used a porta-band to cut my frame off. Keep us updated.
Old Feb 5, 2008 | 08:51 AM
jk007's Avatar
I never ended up having to cut the front frame to get the bumper back on. It just went on fairly easily on both Body Lifts.
The kit I got for my Screw actually had black caps with it, that I had no idea what they were for. They were too big to stick in the front holes of the frame that were now exposed since I lifted and remounted the bumper. So I trimmed them down with a saw, mounted the tow hooks underneath the exposed frame and them put the caps in. Here's a pic of what I am talking about. Look at the black caps above the tow hooks:
Thing is though, I don't ever recall getting these caps with the 2000 SCab we lifted, so I don't know. Maybe I just got lucky...
Old Feb 5, 2008 | 08:54 AM
jk007's Avatar
The vent line that was provdied to us on one of the kits was too big also. We used a piece of rubber hose in it's place. Maybe even garden hose but I can't be sure.
Old Feb 5, 2008 | 05:09 PM
mhockey9090's Avatar
any pics yet?
