Sponsored by: CARiD
AS 2.5" Difficulty
Old Jan 31, 2008 | 07:49 PM
Luke5181's Avatar
AS 2.5" Difficulty
Tommorrow I plan to attempt to install the AS 2.5" leveling kit. I was just curious how difficult this is to install for a first timer. I have pictures and pretty good directions from a previous post, but wanted input from others that have installed them. The most complex thing I have dobe alone on my truck was install power windows and switches for both front and rear windows on an STX.
Old Jan 31, 2008 | 08:05 PM
Blakef-150's Avatar
https://www.f150online.com/forums/sh...d.php?t=318947
Hope this helps
Old Jan 31, 2008 | 08:07 PM
TonkaTruck33's Avatar
its very easy. dont even worry about it. just make sure u dont let anything hang.
Old Jan 31, 2008 | 08:52 PM
davis7210's Avatar
Did mine in 2 hours 14min. Really is pretty simple upgrade. Worth every min!!!
Old Feb 1, 2008 | 12:24 AM
chazf150's Avatar
Don`t worry. If you follow the instructions step by step it should be easy. good luck
Old Feb 1, 2008 | 01:22 AM
Irish FX4's Avatar
I did mine in 2 hours also with a tire rotation thrown in. Dont fret and take your time. It a nice easy project to do. Take wheel off undo five nuts and one tie rod , remove shock and spring assembly, Attach spacer and put back together.
Stand back and admire your ride.
Have fun.
Old Feb 1, 2008 | 08:40 AM
DIHLON's Avatar
Be sure when you put the spacer on top of the spring you put the top in first then the bottom. Also, when trying to stab the upper ball joint back into the spindle, jack up the lower control arm and use a pry bar to push down on the upper control arm to stab it and get the nut started.
Old Feb 1, 2008 | 05:22 PM
Luke5181's Avatar
Well I installed it today, was pretty easy (for the most part) One thing I had problems with was the first real step of removing the 18mm bolt under the sway bar. That thing was a pain in the *** (got the impact wrench) It would just spin no matter where I put a wrench to keep it from spinning. finished it right at 3 hours. Got an alignment, all for $50.00.....not to bad
Old Feb 1, 2008 | 05:32 PM
Irish FX4's Avatar
Nice one Luke. I can see the big grin on your face now. Its always sweeter when you can do it your self.
Old Feb 2, 2008 | 05:00 PM
Luke5181's Avatar
Finished Product
I just wanted to share a before/after pic of the best $130 I hev spent on this truck yet.
<a href="http://s34.photobucket.com/albums/d118/Luke5181/?action=view&current=unlifted.jpg" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Luke5181/unlifted.jpg" border="0" alt="Photobucket"></a>
<a href="http://s34.photobucket.com/albums/d118/Luke5181/?action=view&current=Trucklifted.jpg" target="_blank"><img src="http://i34.photobucket.com/albums/d118/Luke5181/Trucklifted.jpg" border="0" alt="Photobucket"></a>
Old Feb 2, 2008 | 06:11 PM
Irish FX4's Avatar
Looks great! Congrats on a job well done!
