2" AS and 1.5 AAL completed w/pics
Originally Posted by TexasCanesFan
What is the advantage of the AAL over the AS blocks?????
Originally Posted by GIP1979
qt on your aal? Ive heard they squeak? I have 2.5" spacers up front and want the 1.5"aal in back. btw, how much were your skyjackers and where did u get them? HMFIC?
I got my Skyjacker AAL from summitracing.com, about $130. Did the install myself, pretty easy.
Edit: I also forgot to mention that I have netted 2" of lift in the rear on both my 05 and 07 Screws with the 1.5" Skyjacker.
Fifty150, man you really need to reduce the size of that pic. It makes these threads hard to read.
Originally Posted by towrig06
the advantage of a AAL opposed to the block is the ability to still haul heavy objects in the bed and not have it sit nose high. The block will level the truck just the same as the AAL but will not give the additional payload capacity. For example the AS AAL that I put in my truck I think said it increased the capacity by 950lbs. I tow a camper and haul my four wheeler alot, so I thought the extra capacity would be good. If you dont use the truck to haul or tow alot than the block would be fine. And just so you know, the AS AAL has not affected the ride of truck any. I honestly cant tell a difference what so ever. Some people say it stiffens the ride. one last thing, the block raises the rear 1" the AAL raises it 1.5". I have pics in my gallery if your interested.
Thanks for the explanation.
