Sponsored by: CARiD
2' Lowering Kits?
Old Jan 18, 2008 | 12:59 PM
ragencajun's Avatar
2' Lowering Kits?
Sup all, was wondering how to lower my truck 2" in rear. I read alot about people having pinion problems after just putting , like a 2'" shackle kit on without using the shim.
So i call my local "truck accesories " place they said they have a 2" belltech kit that dont require shim, Now i dont normaly trust these guys at these places most of them are just part changers dont really know what their doing, So has anyone done this or had any problems .
They kit i was looking at is a G-force one , its the only one that shows that it comes with shims.
Tks
Old Jan 18, 2008 | 05:50 PM
06F150STX's Avatar
Tks
i ordered one myself, but after i read more about it, it said for 2 1/2" rear springs. i have 3" wide rear springs. so i took mine off, cut them inhalf and added 2" to them and the rear end was still the same height. i don't know since i have the towing package on mine, that i need to add more to it. but, no, i heard that if you are just going 2", you don't need to shim it.
Old Jan 18, 2008 | 08:18 PM
Greg Davis's Avatar
I can't remember the brand, but my first set of lowering shackles did NOT have the shim, and I did get a vibe. I returned that kit (Stylin' Trucks) and ordered the G-Force kit w/ shims, and all was well.
Old Jan 18, 2008 | 08:22 PM
you want a kit with a shim. Shims by them selves retail 30-40 a piece from alignment shops. spend the extra money and do it right.
-Patrick
Old Jan 18, 2008 | 09:06 PM
I think it's part number Ground Force 91200 for the 2" drop shackle and shim kit.
Old Jan 18, 2008 | 09:45 PM
ragencajun's Avatar
Tks for reply's. Yea im going to order the g-force one tonight, The truck right now looks like i have the air shocks aired up all the way. I have 5'inches from tire to fender on front and 9 1/2 on back, even when i pull my trailer it only drops down to 8 1/2. =)
Old Apr 1, 2008 | 05:23 PM
Blue150's Avatar
I am going to revive this dead thread. I just bought an 08 and was looking at the Ground Force 91200 but you guys say its for the 2.5" wide springs and I think mine has the 3" as well. Is there a kit for the 3"?
Old Apr 7, 2008 | 06:45 PM
ragencajun's Avatar
Sup,
Yea the 91200 is the one i ordered from amazon.com 04 and up have 3" wide springs. I put mine one with no problem except there is a weird peice of lead placed above my left rear frame rail.(have no idea what it is) but it blocked gett'n the bolt out enough .
My truck now sit's 5" in front and 7 1\2 in the rear.
Try and get some pics up.
Old Apr 7, 2008 | 08:41 PM
naplesbill's Avatar
I just installed the GF shackles on Saturday. The entire installation took less than 2 hours. I had a slight vibration in the rear and I thought it was a balance issue. After installing the GF kit and shims the vibration is completely gone.
Old Apr 7, 2008 | 09:00 PM
That's great!
Old Apr 7, 2008 | 09:53 PM
naplesbill's Avatar
It certainly made my day!
Old Jun 26, 2008 | 01:06 AM
dirtysnow's Avatar
my gf shackles have 2 different holes to use. im guessing one set is for 2" drop and the other for 1" drop...? my question is, if i only use the 1" holes do i still need the shims?
Old Oct 3, 2008 | 01:22 PM
08Ford FX2's Avatar
Sup,
How did you get the bolt out & back in with that plate in the driver's rear.
